11.5"x7.5"x4" , From a piece of Walnut over 100 yrs. old . When finished does that make this Eagle an Antique ? Ha,Ha. To this point it is done with the Band Saw , no Hand Tools .This removes a lot of Excess Wood . Makes one Heck of a lot of Saw Dust . Need to Clean up before making more with the Hand Tools . Should be Interesting and Fun . Merle 1-IMG_0003.JPG 2-IMG_0001.JPG 3-IMG_0002.JPG
Starting a Stylized Eagle from Walnut
That is some nice bandsaw work Merle. Just put some finish on.If I took the time to fix all my mistakes, I wouldn,t have time to make new ones.
www.spokanecarvers.com
Hi Tom , a lot of Wood still needs to be removed before the Finish . Doing the Band Saw work I use a lot of Duck Tape and run the Blade Gard up as high as it would go , it just fit .Saves a lot of Hand Work . Here is a Picture of what it is supposed to look like . I make changes as I go . Happy New Year Tom . 1-Scan-001.jpg
Hi Arthur , I'm not even going to try my Hand Tools , this will be Power Tools all the way . I think I'll use just a Poly U Finish and let the Grain do it's thing . As you can see I changed the Base , thought it needed a Higher Base . The Wings look kinda Fragile , may be a Problem . Thanks Arthur for your Always Welcome Comments . Happy New Year . Merle
What a beautiful piece of wood to work with and a great design. As far as the wings go, the thin wings and design is always a worry... I used only dremels for them once I got them thin and did tons of sanding vs carving, a lot more time-wise but ten times safer....., any kind of vibration from the flex shaft had me worried because of the more power. Of course, some hardwood can be shaved really thin if they have the right grain structure. The wood I am using now is a new hardwood for me, I am major testing the breakage point on it before I get into the final design of the wings by testing out various bits and burrs and vibration levels....each wood seems to have its own perfect set of bits and burrs. My flex shafts I use for sanding these days.
Hi Di , Thanks for pointing out about the Vibration on the Thin Wings . I was thinking about using my Reciprocating Hand Tool with a V Tool . ( Gingerly ). Maybe trying Various Speeds on the Bits will help reduce the Vibration . Trial an Error is always a .Good Learning Experience . Ha,Ha. Thanks Di , have a Happy New Year Merle
That walnut is beautiful Merle This is going to be a great looking sculpture. You could do alot of the initial shaping with a heavy grit sanding disk and drum sander on your drill. I have never had a lot of success with a reciprocating tool on walnut. Do not know if it was the tool or me. I look forward to hearing how you progress.
Hi Randy , I have a couple of Cutsall course Bits that will take off the Waste Wood fast . For the next step I'll use a 3/4 " Drum Sander with my Flex Shaft Tool . On my Walnut Cane Toppers I used the Reciprocating Tool and it went thru like Butter , hope it's like that on this Piece . Today I'm not going for Detailing just getting a Rough Shape for tomorrows Detailing . Those Grooves in the Wing looks like Trouble for me . If so I can always put Feathers instead . Ha,Ha. Again it's only a Piece of Wood so have Fun . Thanks Randy Happy New Year Merle
Happy New Year, Merle! That is going to look great in the walnut!
Very nice job Merle, looks awesome.Mark N. Akers
