Bar & Chain oil
  • Bar & Chain oil
    Does oil affect your carvings? seems like residue might cause finishing problems...
    Or maybe I just think too much.
    Buffalo Bif
    www.bflobif.com
    Re: Bar & Chain oil
    I think not using bar oil will cause a much more serious (and expensive) problem.
      Re: Bar & Chain oil
      I work on saws for a living, and I'll assure you, you have to have bar oil! They make biodegradable oil, that might be better, but it can be hard to find. I have also seen people use vegetable oil, mainly butchers that use a saw to split a beef carcass. Don't know if it would be any better than regular oil, but might be worth a try.
        Re: Bar & Chain oil
        I've carved an awful lot of wood that was cut to size with a chainsaw and have never had a problem with finishing them. In fact all my fish are carved from aspen cut down to size with a chainsaw. Any wood coming in contact with the bar and chain is whittled away anyhow.
          Re: Bar & Chain oil
          First of all, I have no intention of not using oil in my saw. Does anybody do that? Guarantee they dont do it for long. Thanks anyway for that advice. Second, I'm talking about carving with a chainsaw, not bucking logs. Just wondered if the oil caused any finish problems. I suspect it would be a non issue if the finish were spirit based....
          Buffalo Bif
          www.bflobif.com
            Re: Bar & Chain oil
            The only way you can get by without oil is ice block carving and then I use vegetable oil. I don't believe the oil does a thing to a carving and I have done a few.
              Re: Bar & Chain oil
              I have airbrushed some acrylics over couple of chainsaw carvings that got splattered pretty good with oil. I was concerned but now its been nearly 2 years with no issues.
              Greg
