I found a small mallet, approximately 6-8 ounces, at a local Goodwill store. It's in pretty good shape, just one area where the wood looks a little stressed from striking. But the finish is wonky on it, mostly gone. I'm not sure what the finish was. The neck where the handle joins the head has a bit of waxy finish on it. I recall seeing mallets somewhere that had a waxy coating on them.
I'd like some advice on what to do for this mallet to bring new life to it. Should I sand the old coating off and apply a new coating? If so, what should I use? Thanks in advance.
Lizabeth
Edited to add: The finish looks sort of like worn-off polyurethane. Does that make sense?
Lizabeth
