Cut Walnut , Basswood , Oak , Cherry , and Mahogany ,into 1 1/2 " Squares and Drilled a 1/2 " Hole in center . Gluing a 7/16 " Dowel up thru the center , that gives a lot of Room for Glue . Don't know how it will turn out , but has my interest . Merle IMG_0012.JPGIMG_0013.JPG
Trying a different way to use up Scrap Pieces
Originally posted by Brian T View PostYou can bulk up the dowel by wrapping it with cotton string. That mixes well with the glue.
Common stunt to get a fishing rod blank to snug up to the cork rings for the handle.Bill
OK. There's a gap between the diameter of the wooden dowel and the diameter of the drilled hole.
Wrap the dowel with a layer of cotton string, just enough to mostly fill the void.
I've got some thick cotton string and some skinny butcher's cotton string ( for roasts, rouladin etc).
I'll pick the one that best fills the gap in a single wrapping layer.
Now goop up the rod & string with glue then push each block down over that.Brian T
- Likes 2
here are a few shots of such a stick our carving club put together, donated to the local area show, for them to raffle off. called a friendship cane. each carver submitted a 2 x2 x3 block carved.
- Likes 2
