Hi Merle
Listing progress on the D28 guitar build as promised. This is only the second guitar I have built and is quite different to the archtop one I did last time.
The first photo shows the neck laminated from 5 pieces of wood and a truss rod has been fitted in the centre so the neck can be adjusted. This is a tight fit and is packed in thin felt to prevent vibration rattle.
A 1.5mm strip of wood has been fitted over the truss rod so that when the fretboard is glued on the excess glue can't get down around the truss rod and ruin its function.
The third photo shows the neck rasped and sanded to shape. I used profile gauges to get the profile exact at different points on the neck. The dovetail has been cut to fit it to the body. The neck is set to a 1.5 degree angle as per the plan.
Fourth and fith photos show the headstock laminated both sides ,The access hole cut for trussrod adjustment. Holes drilled for the machine heads and the heel fitted to the dovetail.
sixth photo is the mould I have made to build the body in. this has been sanded and sealed since the photo was taken.
seventh photo is all the internal top and back bracing. This has been made from Sitka Spruce.
Making the neck is the hardest part of the job as it has to be spot on and all the angles and profile make it a painstaking proccess. All shaped by hand as were the braces. I use chalk on the profile gauges and just keep taking off the high spots until it fits.
That's about it so far.
