Jambalaya Spoon
  • Jambalaya Spoon
    I made a jambalaya spoon for my son a few years back and just noticed it has a largish chunk missing from the front of it. I think this one was walnut. So, for a little treat for him, I made another. This one, like the previous one, is 16 inches long and about 7/8 inch thick on the rest. His jambalaya pot is pretty good sized and he wanted one this big so he can make a full pot and still be able to stir it.
    I picked up a piece of curly maple (Acer spp.) at the local hardwood lumber store and proceeded with that. After cutting out the outline on the bandsaw, I clamped it to my bench and began hollowing out the bowl.
    After a bit, I had it down to 1/4 inch depth, roughly. I figured by the time I smoothed it out, it'd be close to 3/8 inch deep.
    You can see, I hollow the bowl before I round off the back - makes it more stable on the workbench.
    Now hollowed out, and the back of the bowl rounded. The handle is also rounded on the corners. I left it mostly square so it would be less likely to twist in his hand when he's using it. I used a different radius for each of the front corners to make it easier to get close to the curve in several different pots.
    And here it is after the sanding. I did the basic sanding with 100 grit, then switched to 220 grit for the smoothing. When it was done, I then wet all over in the kitchen sink, dried it with a hair dryer, then sanded with a used piece of 220 grint. Did that cycle twice, then switched to 400 grit and did the wet/dry/sand cycle twice more. At the end of that, it was still smooth after wetting and drying it. After it was all dry. I followed Brian T's recipe of 325° oven for 3.5 minutes with olive oil slathered all over it. The oil really brings out the grain of the maple.
    Nice one claude. That should last him for years.
      That is exactly what a kitchen prep spoon needs to be. Should last a life time, finish and all.
