Hi Guys
I had a nice piece of chestnut that developed a huge crack down the middle over a couple of years drying. The 1/4 inch wide crack didn't quite go full length through the block So I cut it in half and cut blanks from the piece with the bad crack in it. Will be able to get a bowl turned from the big bit.
One of the blanks had beautiful striations and grain pattern but also a number of flaws in the block. How to make the best of it as I didn't want to wast it ? See photo, flaws marked with an x.
I decided to go with a design based on a rock oyster pattern and drew it up so that all but 1 flaw were removed. I left that one as it wasn't too bad and I needed to get a balance to the piece that would not be so good if I cut the flaw out.
I then cut the outline out on the bandsaw and cut the bowl with the big gouge. I found the rubber hammer worked better on the big gouge and was way less noisy.
Once roughed out I sanded it down through the grades to 1000 grit then buffed it with goddards silver polishing cloth until it got a shine on it. The cloth has a super fine abrasive in it that works wonders for getting a good final gloss on the wood before applying a finish.
No finish has been applied to ther piece yet. Doing it this way I will get everything the grain and striation patterns have to offer from the wood.
Tomorrow I will shape the outside and start on the finish.
