Chip carved illusion
  • Chip carved illusion
    While waiting to start the relief of Escher's "self portrait" I decided to do a chip carving like this one by Emma Perlaky that appeared in the MyChipCarving.com E-newsletter. I had a 12" plate blank, so all I had to do was enlarge the photo to fit my plate - Wrong! It was quickly apparent that the "break" in the pattern (where the distortion begins) had to fall where the center recess of the plate begins. Mine was off by 1/2 inch!
    So I had to modify the design to fit my plate. This required a lot of analysis as to how the original design was made. It also required drawing the modified pattern on my plate, a real challenge! The chip carving should be easy in comparison.
    Re: Chip carved illusion
    Whoa!! Very nice work!
      you got more courage than I do
        Wow an optical illusion! Beautiful!!!
          Very nice piece, Phil!! Your coloring made this piece work. This is a winner! Thanks for sharing.
            No, no, no! ! The photo is still of Emma's carving. I'm still getting started.
              Neat! as an artist I can draw this kind of thing, but to carve it from wood? Yikes!
                Doesn't look all that hard to do, when you break it down. I'm sure yours will be spectacular.
                S~
                Carvito ergo sum.
                  All I can say amazing Ginny
                    Good Luck with that Phil.... If it doesn't make you dizzy first! .....
                      Thanks Phil. Nice optical illusion.
                        Wow! That is awesome work!!!!
                        Wanda
                          I finally succeeded in adapting the pattern to the plate blank I have. It required making new templates for the curves in the distorted part. Now I can begin the chip carving and will share photos with you soon.
                            Beautiful, love the coloring!
                              Thanks for all the compliments, but the photo at the beginning of this thread is NOT MY CARVING. It is the work of Emma Perlaky as pictured on the MyChipCarving.com site. I am using the photo as the starting point for a new chip carving WHICH I HAVEN'T DONE YET!
