Caged Ball in Relief
  • Caged Ball in Relief
    While going through my available wood I found a piece of butternut with a large area of bark, leaving only a triangular shape for carving. After thinking about it a while I came up with the idea of a ball-in-cage that is only half of its normal shape - a caged ball in relief. The cage will have only three bars and the internal ball will be only a half ball with its edges slotted into two bars.
    This calls for some precise shaping, so the half ball doesn't fall out. Here are some beginning photos:
    Re: Caged Ball in Relief
    That should keep you off the streets for a while! Looks like you will have some excruciating internal cuts to make.
    Keep us posted.
    Arthur
      Very interesting project - do keep us posted.
        This project is going well - now starting to shape the half ball. When released, it will be able to move up and down in the cage, and to rotate in one plane (but not out of that plane). The third photo shows the flat back side.
          Cool!
            Very neat. You never go for the easy stuff. Good for you!
              It dawned on me that some viewers might not see the difference in this caged ball. The photo below shows the present status of the carving. The upper sketch on the right shows the cross-section thru the middle of it. The outer edges of the half ball will rest in grooves in the "pillars." A close clearance of the ball curve to the center pillar will keep the half ball from "cocking" and falling out. It will be able to slide up and down, and rotate.
              The lower sketch is a cross-section thru a typical ball-in-cage.
                Very interesting project. I really like your gallery a lot! You have been carving a long time and a master at it. Thanks
                  The half ball is now released and can move up & down. Here are two photos comparing this project to a regular ball-in-cage. They also show the final decorations I may put on this one.
                  I realize now this should have been called "A Half Ball in a Half Cage."
                    This "Half ball in a Half Cage" is about done. I usually leave these whimsies natural. Butternut - 1-1/4" x 2" x 5-3/4"
                      That has turned out really nice! I love the unique design and the piece of butternut that you chose is beautiful.
                        I agree with Dicky, Phil - you seem to always pick an interesting challenge...and then accomplish it well!
                          Well, after seeing all the pictures that show ya how to carve a ball in a cage . I might just have to try one. Thanks Ginny
                            Here are some photos illustrating this project: On the left is a conventional 4-sided ball-in-cage. On the right is the 3-sided "half ball-in-half-a-cage"
                              Very interesting project...I'm sure that took a lot of careful planning and cutting.
                              Keep On Carvin'
                              Bob K.
