I've tried to carve a little buffalo using Deseree Hajney's Rolling Animal pattern. Please critique the carving (I know it isn't perfect). Do I need to burn the fur in before I paint it? What kind of paint do I use? I want it to be safe for my one-year-old granddaughter!
Little Buffalo
Re: Little Buffalo
Cute carving, Hazel! I know your granddaughter will love it. Isn't it fun carving for grandkids?
If you intend to burn in the fur, do you intend to use a translucent wash for the paint job? Have you ever tried dragging a fine-tooth saw blade across a carving for fur? It will give you a finer texture, usually, and you can highlight certain areas by burning.
For paint, I recommend acrylics thinned way down with a matte medium, or water, followed when dry with a satin spray finish...check the cans for one that is child safe.
Hope this helps.Arthur
Re: Little Buffalo
Oh, he's cute! Does he roll? The pattern has some shading and arrows on it. I wonder if you could burn those areas only and then just lightly paint or stain him. Please post your finished carving. I've thought about doing the pony, but.....It looks complicated.
Re: Little Buffalo
I agree with Arthur about the acrylic paint as a wash. Burnt Umber would be a good brown color to use. I don't spray my carvings with finish - I use a 50-50 mix of water-based satin or gloss varnish and water. The thinning does a good job of sealing the paint in and doesn't make it look real glossy. I did the bear for my grandson several years ago. I carved it out of a block of walnut, so I didn't need to stain or paint it.
Re: Little Buffalo
It wasn't as hard as I thought it would be, Debbie. Once I quit trying to carve two directions at once. Carving from a three D pattern is a learning curve! Arthur and Claude, I'vd done a wash on him in brown and black and have done his hooves and horns in a metallic black. He looks pretty good, but I do think I should have burnt the long shoulder hair. I think I will seal it with food grade Watco oil and finish. Thank you all for your comments and input!Hazel Strickland
AKA Dixie Whittler
Re: Little Buffalo
I just found an old post from kaofan of a bison he carved in Desiree Hajny's class. I should have burned the fur. I'm gonna try another one...practice may not make perfect, but it does make improvements!
Anyhow, here's my little guy finished.Hazel Strickland
AKA Dixie Whittler
