Power engraver questions
  • Power engraver questions
    Hello, I'm new here with a question. I recently got a Russian made power engraver/carver. I wanted to try out carving before investing in more $$$ tools. It says it needs oiled with a spray oil, but there were no instructions as to where it gets oiled and or what type of oil. Would chainsaw spray oil work? It' a turbine carver with 2 pipes at top. One for air, naturally. I assume it would be taken apart to be oiled. How often should it be lubed? Thanks!
    The turbine carvers that require oil require a light oil designed high speed tools. I would not think chain saw oil is what you want to use. Have you looked on you tube? If you know the name of the tool you may be able to find a video on its use. Most of the newer such tools are oil free. Look close at the area where you air supply attaches to your hand piece there may be a very small hole on the air tube. That could be for the oil. But I would not use it until you can fine answers to you question.
    Randy
      oil.jpgI use an oil for engravers purchased from Lew Jensen who designs and makes the engravers.....from Profitable Hobbies. Engraving systems needs tons of learning stuff, you need to clean your hand pieces and care for everything.....they have videos and books also. I had to buy a major dvd system to learn the whole deal....tons of learning. Engraving systems cost big money.....but worth the major investment. They will also give you information over the phone.
      This is the oil I use. All oils must be pure and special made for engravers....this cost about 12 dollars plus shipping..... High Grade Oil for the use on the 8oz. of High Speed Spindle Lubrication for use in the engraving Handpieces. Also use to clean and flush the Turbine.
        A picture might help;
          Sorry I can not get my links to work..... so go to You Tube and this is the heading.
          oil regulator.jpgFilter – Regulator – Lubricator Set Up and Why You Should Use One
          A filter – regulator – lubricator unit (abbreviated FRL) is an important part of your high speed engraving system. It performs three important functions:
          1. Filter the air before it is delivered downstream to your handpiece.
          2. Regulate the air pressure before it gets to your handpiece.
          3. Lubricate the air traveling to your handpiece (unless you are using an oil free handpiece).
          Filter - Regulator - Lubricator for Engraving
          I have filter regulators ....that hold the oil and they spray the oil into the hand piece for the engravers that need oil. I was helped also by a few members in here with problems...like Denny who I have not seen for awhile.
            handpiece-.jpgthis is what most handpieces look like at the top. The very top part is to push the bit or burr out and it just pushes down. The round side piece is put that clear tube ( in picture of filter/regulator)....the clear tube fits over the top of the round hole fitting and the other end of tube fits into the filter regulator. The filter regulator other side fits into a larger tube that goes to your compressor. .
              High speed turbines use advanced bearings and the smallest dirt or such will collect and shift the axis. The big power plants have steam turbines that used to destroy the building as one end would weld itself solid with the turbine driving at only 3600 RPM and weighing many tons flies through the air. I started a program of measuring the vibration sound at a Dow plant I visited. A Chlorine plant from Mississippi river or salt domes when water was low. I would measure audio and sub audio vibrations and above a threshold they were instructed to change them out. After the program was implemented, they never lost a turbine. The program (I was using an early PC, MITS in 1977 or thereabouts.) Analog signals. High speed anything requires balance and 'running true' or it runs wild.
              I cut with a plasma torch for years with CNC. The air supply was filtered from dust 4 times in the line and a refrigeration unit to dry out the moisture. Any of it and the beam of electrons would start to deflect and erode the focusing lens. That would cause a slanted beam and an out of control cut which destroyed product under production. I was cutting out items smaller than your thumb nail. Small chickens.
              Keep it clean, clean, clean. And as Dileon mentioned, wash out the turbine to get anything present from wear or tear out.
                Thanks for all the tips! I appreciate them greatly.
