im looking for a flex shaft special rasps( carbide ?)
  • im looking for a flex shaft special rasps( carbide ?)
    hey guys i would like to carve big pike and musky lures. ive start with a gouge but i think ive found something quicker. does anyone know the name and model of these please ? https://youtu.be/9hjjW14gSGs?t=5m53s
    and that one https://youtu.be/1Wlgdth5F6o
    im i wrong when i think it's quicker than a gouge ? btw feel free to suggest me another kind of carbide if you think it can remove more wood and quicker than these youtube ones.
    i hope someone can find it , im so happy to know something like it exist. my flex shaft model is foredom sr
    easy with my english ,it's not my first language
    cheers
    You might do a web search for A-KB66544 Typhoon Carbide Bur, Smooth End Cylinder (Coarse)
      Try this site - http://chainsawsculptors.com/saburr/dremel/index.htm They have 1/4 inch shaft burrs and 1/8 inch shaft burrs.
        In the first video, it is a safe-end cylinder-shaped carbide bur. In the second video it's a bull nose cylinder shaped carbide bur. You can find them on the Foredom website (Foredom.com), SaburrTooth (saburrtooth.com) or Kutzall (www.kutzall.com).
        Cylinders are good for roughing out, but to really move wood, I prefer the carbide bur sleeves (that fit onto a rubber sanding drum). You can change sleeves to change grit, just like a sanding drum, and they are usually longer, so you have more working area. The ones I use the most come from SaburrTooth.
        Best Regards,
        Bob Duncan
        Technical Editor, Woodworking/DIY
          These Monster burrs are some of my favorites, but they are kinda pricey. I only have a couple.
            I think I would go with a set of sanding drums, from a 1/2" diameter up to a 3/4" diameter by 2 size. But I also suggest looking at how pipemakers use a French sanding wheel to shape pipes and stems. They also use belt sanders, a 2x42 slow speed sander with an 80 grit belt would okay, but a 2 inch wide 72 inch slack sander would be a better choice.
              guys thanks a lot for all your helpful reply ! really appreciate
                it look like my h30 will not work with these 1/4 ;( does anyone want to trade it for a 44 ? i have no problem to ship first .he is brand new
                  guys could you suggest me a good place to sell carving stuff other than ebay ? it look like there is no place for that here?
                    here is mine. i think the choice for 1/8 is not really good.we have more choice for the 1/4 right ?
                      Best Regards,
                      Bob Duncan
                      hey bob https://youtu.be/mIQdR_U_xqM?t=1m38s
                      something like that ??
                        Yes, that's similar. Here's another one:
                        http://www.woodcarverssupply.com/1_2...ctinfo/259801/
                        (if you get the mandrel, it works for both sanding sleeves and sandpaper drums).
                          it look really sweet. how about that one ? which one should be more aggressive ? https://www.woodcraft.com/products/e...coarse-3-4-x-1
                            One thing you got to remember using the extra coarse, you have to stop removing before you get to the exact desired shape, there is some clean up to remove all the groves left by the extra coarse, just my $0.02
                              for sure,maybe im wrong but i guess it's almost the same time ,the guy with a coarse bit will get is shape faster but he will have to sand more than the guy with a smooth burr on the other hand the guy with a smooth one will take lots of time to have his shape done but he will have to sand less ? does it make sense ?
