I currently have a Foredom TX Series flex shaft as well as a Foredom Power Graver with a NGraver handpiece used for engraving metal but also cuts wood well with proper bits. After Covid I have had issues with hand and wrist pain and am not really able to use conventional hand tools. Would a Micromotor such as the Strong 202 with carbide bits be a good choice for fine detail carving in European Boxwood. Subject sizes would be smaller, most being 2 to 5 inches in each dimension at most, some even smaller. Thoughts?, opinions are appreciated on the tool type and brands if that’s allowed. I believe my current tools will be adequate for rough work but the finer details will be the challenge. Thanks in advance for answers.
Recommendation for Micro-motor for carving European Boxwood
The strong 202 I a good unit. I think there are a number here that use it. I use my Foredom for rough out and my mico unit for more light shaping and detail. With hard woods you have to let the bur do the work most mico units are limited on their torque and will bog down with to much pressure. This is a good information shet on power carving burs.
https://woodcarvingillustrated.com/b...-carving-bits/We live in the land of the free because of the brave! Semper Fi
- Likes 1
Hi Alan
I have a NSK presto unit for fine detail. Haven't had it long and haven't really spent a lot of time on it as yet but it gets around at 320,000 rpm and is light in the hand and is a bit like a really fat pen. You can get a range of burrs for it that are cheap. You will need a small air compressor to drive the thing though. I found it pretty good for feather detail.
