Bark on wood slices
  • Bark on wood slices
    I am working on items for Christmas. I cut oak slices about 3/8" thick, 3" diameter for ornaments. I plan to wood burn on them and would like to have the bark stay on. Is there a way to seal/preserve them so the bark does? I have googled and found many different answers. Thought I would pick your brains. Thanks
    Dean
    Hi Dean, What I always do and seems to work is , I put about 3 Good Coats of Poly U on the Piece. I really Soak the Bark . That is Simple and Holds Good. I did that on the Rotted pieces of Walnut and is Fine. Merle
      Hi Dean
      You can always use an air compressor and a brad nailer, leaves very small holes
      Bruce
        I will try poly u. Thanks
        Dean
          Hi Dean, I don't think you will Sorry. Try it on a Piece of Scrap first to be sure. Merle
            Hey Dean, looking forward in hearing your results on your Bark Problem. Merle
              I wood burned the slices and painted highlight areas. I am buying the poly u this weekend and will let you know. Thanks
              Dean
                Hi Dean, Don't try to cover the Bark in 1 Coat , I found about 3 good Coats works well. Merle
                  I put 3 coats on today. Ornaments are ready to go. Thanks for the suggestion Merle.
                  Dean
                    Hi Dean, Your Welcome , Glad to have Helped. Merle
