To Hard to Carve , so I Burnt it
  • To Hard to Carve , so I Burnt it
    7 1/2" x 6 1/2" x 5/8" , Mahogany , Finished with Poly U only . This is the Piece that I was going to Carve but was to hard for my Tools so. I Split it and decided to see what it would look like Burned . I found that a lot of my Shading Disappeared after using Poly U . Good Dust Collectors for the Daughters . Merle IMG_0003.JPGIMG_0005.JPG
    Looks great, Merle. I admire your patience with burning all those feathers.
    Website: http://www.ronmarr.com
      Another great set of wings Merle.
        Nice design, great job.
          Hi Ron , I had to do the Pattern 3 times . 1st was to burn thru the Pattern ,then after Sanding off the Glue residue that removed some of the Pattern , and then after I missed some of the Glue . The Wood was to nice to Scrap and if the Burning didn't turn out good the Wood would still look good , Win ,Win situation . Thanks for commenting . Merle
            Hi Randy , That's enough Wings for awhile . Thanks Randy . Merle
              Hi Bob , thank you for commenting ........ Merle
                A very nice piece and fine pyrography, Merle.
                  Hey Merle, what type of printer do you have, if it is an ink-jet, I might have a suggestion to help with those pattern transfers∙∙∙∙Great looking wings
                    Looks good
                      Hi 807, my Wood Burning is just Basic and no Clean up after . Thanks for your Kind Words . Merle
                        Hi Joe , my Printer is HP ,Envoy , 5540 , don't know if it is a Jet Printer or not . Thanks Joe . Merle
                          Hi Christ , thanks for commenting .... Merle
                            Yupo Paper L21-YUP197W912 White Sheets, 9" x 12", 10 count
                            If your interested, I got this from Amazon, With it you will able to print and image, turn the inked side down and rub your image off on the wood, I always set my printer setting for"best quality" & "darkest". The paper will have to be trimmed down to fit your printer, & once you get your image transferred, you can wipe the paper with alcohol & even though it leaves a little stain It can be used again. Maybe another arrow for the quiver?
                              Hi Joe , never heard of this Paper , sounds good , will check it out . Thanks Joe . Merle
