In Case Of Emergency!
  • In Case Of Emergency!
    Been wanting to get this finished and up just in case we happen to be away and something happens to the house. I had one up for our other pooch but since they're personalize with names I took it down when she passed away.
    The wood is 4/4 basswood from southeast Tennessee. The woodburning was accomplished with a Colwood Detailer and the initial painting was made with water colors.I had one "unhappy" mistake in the finishing process. Before I started applying the water based poly I sealed it with Krylon Matte Fixative. However when I buffed it after the first poly coat with a paper bag to smooth the surface out in preparation of the second coat, the paint smuged. For the most part I was able to touch it up using thinned out acrylic on top of the first coat but I didn't try to do anymore buffing on the remaining coats for fear of further smugging.
    Oh You , You are so talented and what a great project too. And for a real true reason, that is good. How do you do the lettering?
    Thanks for sharing this one too, Eddy.
    Chuck
      Delilah takes care!!! Great sign.
        Hi, Eddy, Nice Job, very well done . Merle
          Making the lettering is the easiest part of the project. I decide how I want the sign to look. In this case it's just a bit larger than 8-1/2" x 11 so I picked out a font that's on my computer and laid out the lettering and graphic to fit a standard sheet of printer papper. Once printed out I afixed a sheet of graphite onto the piece of wood and then the sheet with the design on top of it. From there it's just tracing out design with a pencil. When all is removed the design is transfered to the wood.
            Nice work, Eddy! Also, a very important item to have outside by the front door in case of emergency.
              I DID NOT think of using the computer!!! Drats.
              Chuck
