Making burning Tips from Nichrome wire
  • Making burning Tips from Nichrome wire
    I just obtained a Razortip Handle with pieces of different sizes of wire to make my own tips, I would appreciate information on making the tips. Like do you get the wire red hot before flatting the wire & bending or can you do this cold? Thanks
    Re: Making burning Tips from Nichrome wire
    The ones I flatted out, I got red hot. I used a ball peen hammer to flattened after i shaped the tip part a round a needle nose pliers. I used another hammer for the anvil. I think i even used an upholstery hammer to tap the hot wire on some. Some of the ones I flattened, I took needle nose files and filed grooves into them for "special" effects.
    The wire will get brittle if over worked and needs to be annealed.
    I had fun making the tips. Reminded me of when I used to make hand wrought silver jewelry in high school.
    My ETSY shop:
      You need to get the wire hot, then as you tap the hammer on the wire you kind of pull the hammerhead back towards you to extrude the metal. I have an old piece of railroad rail I use for an anvil and a small ballpean hammer.
      Larry
        Magicman, check out this website Make your own fish scale wood burning tips and wood burning pens by Ed Walicki
        Ed W. has a great tutorial posted. Dick M
          Sue Walters Pyrography Workbook has excellent info in Chapter 5 on making tips. A Fox Chapel book...
            Thanks for all the information, sounds like I can do it!!
              I have a Tekchic 110V Woodburning unit and I would like to make a writing tip. I have some 50w tips already but not a writing one. I read you use I chrome wire to make them but I don’t know what gage I would need to use to make them. Any help here would be appreciated. Thank you
                Fuzzy memory Connie, but there was a fish carving site (?) years ago that explained it all. Might want to do a Google search. A member posted an article about making a wood burner and tools. I have it somewhere here in the computer and will see if I can find it. Nichrome wire I think it was...
                  A lot of info on this site and the web...just do a search. This is the article I referred to: "https://fishcarver.com/making_fish_scale_tips.htm
