I finished this carving late last fall and forgot to post. It was based off of some pictures from an all-white piece in an antique auction. It is the largest caving that I have made at about 18 inches wide and tall. I had to glue up two pieces of 4-inch thick basswood for the blank. I used a bandsaw to cut out the blank and then an angle grinder with a 40-grit flat disk to rough in the shape. From there it was hand-carved with my Pfeil chisels. Carving the feathers on the head and neck and carving the claws were the biggest challenges. It is hard to capture on a picture, but there is actually clearance between the base of the claws and the shield. For that I added a few very narrow (3-4 mm) chisels to my arsenal.
I'm not sure if it is finished as I had originally planned to paint the shield red, white, and blue. When I finished with just the gold paint, I kind of liked it. Now, I'm not so sure. Any constructive criticisms or opinions on painting the shield are welcome.
Thanks,
Thanks,
