Back in the good old days when my wife and I could make the trip up to our cabin just south of the Smokies I use to spend a lot of time on my front porch making canes. I've given most away now but I kept a number of them for my own use. Recently, my balance and equilibrium has gotten so bad that single point rubber cane tips don't quite provide the stability that I need. Another thing that I found is that the canes that I kept for myself are too short for long term use. Evidently, when I first sized them I did so improperly and when I use them now I tend to bend over more than I care to.
So, this week I ordered a quad footed cane tip off of Amazon and added a 4" extension to an existing cane to make it more functional. The quad foot accepts 7/8" wood canes and to make it fit I had to remove approximately 1/8" from the end of the cane that goes into the quad tip. I spent a lot of time searching for quad or tri-tips of 1" and larger but in doing so I only found this 7/8" product and one 1" quad tip. However, I didn't like the reviews or the description on the 1" so I chose to modify rather than order the larger tip.
The extension that I added to increase the shaft length was easy as I had modified another cane earlier. I took a piece of yellow poplar branch that was left over from another project and whittled it down to match the same diameter as the cane itself. Then I drilled a 1-1/2 " hole in each piece and then joined them together using a 3" by 3/8" dowel with plenty of Gorilla glue. I didn't have any stain to match the existing cane so I just finished it off with 4 coats of acrylic poly. I added the wrap just to hide the joint but when I get the ambition I plan to remove the wrap and add a Turk's Head.
It may not be pretty but works like a charm. The cane not only provide more stability but it will now stand up by itself instead of having to be laid down flat creating a trip hazard to anyone coming upon it.
I would recommend one of these quad tips to any senior that has difficulty with balance. I'd also like to see manufacturer's add tips that will receive larger sized diameter canes. "Tree Line" does make a neat single point , two piece, cane for a 1" walking stick for both fair weather and snow and ice use. It's easy to install but isn't offered with a quad tip.
