Walking stick
  • Walking stick
    I’m working on a walking stick for a friends Dad and wanting to leave as much of the bark on it as I can.
    What could I use to coat it to keep it from chipping it off easily?
    Thanks in advance
    Thanks,
    Greg
    The Sticks and Canes that I leave some Bark on I just put on some good Coats of Poly U . I pretty much Soak it . Seems to do the Job. Merle
      Thanks Merle
      Thanks,
      Greg
        Like Merle I will poly some sticks, depens on the bark. Sicks with a thin bark like hawthorn or holly and others the bark will hold up a bit better than the thicker barks. On a thicker bark I use tung oil first. A good coat with a soft brush, I let it sit for a 1/2 hour then blot off any execess and use a soft brush to clean out any low areas with build up. Let the oil cure. Depending on temp and humidity this can take up to a couple of weeks. Then I fallow with a couple of coats of poly. This seems to help to keep or greatly slow the bark from drying out and pulling away from the stick.
          Poly or varnish, spray or brush on!
