Band Saw
  • Band Saw
    Looking at purchasing a small bench top band saw. I don't have the space or desire to buy a large model. There is a model made by Skil and I have given some thought to that. Sawn out blanks are more to my liking. Thanks for your input.
    OF
    I have one and seldom use it because I carve smaller pieces directly from the blocks. Seems to do the job when needed though. I got a finer saw band because the one that came with it was coarser than I needed for the smaller cuts.
      i have a 10 inch craftman that isnt a bad saw at all its more dependable than my 14 inch rikon and the blades are much cheaper i wouldnt get a used one unless you really are familiar with saws but you have other options one of those handheld rotary saws can do a lor and then there is that saw eith a single oscillating blade similar to a scroll saw which is another option. I went for years roughing out with a big gouge but seldom do so now my best suggestion is the 10 inch sears
        Send a PM OF and I'd give mine away if you are in the area...
          It is a long way from the Great Lakes to the Oregon coast. Thanks very much for the offer.
            Most saw makers have a bench-top band saw in their line-up. Slight design changes but clones.
            Mine just happens to be a Delta, had it for years. Sometimes used a lot, some months gathering dust.
            I bolted it to a piece of 3/4" plywood for portability. That is just clamped to the bench. Nothing jumps around at all.
            You really need some sort of dust control, the saw can pump it out at a good speed.
            I stick the nozzle of my ShopVac into the exhaust port. Noisy but with muffs, it works.
            Get a cheap 2" long bristle paint brush. Keeping the guts clean is a good plan.
              Dang, waaaay too far.
                I have a benchtop saw at my place in Florida and a 14 inch at my home, other than the the added 2 inches of thickness the larger saw can cut I don't see much difference. Just don't get a small saw with 3 wheels.
                  Have a 10 inch Craftsman works great
                    I have a benchtop Ryobi that has worked well for me. The choice of blades will be an important factor regardless of which brand you choose.
                    Arthur
                      As Arthur says, the blade is very important. I bought a 9 inch Craftsman with a brand new Craftsman blade and it didn't cut worth "stuff". It would not track straight, and I could only cut a curve to the right... I was a bout to junk it when Lynn Doughty recommended a Timberwolf blade to me. That first blade was a wonder! It tracked straight, it would cut tight curves in either direction. I've never bought any other brand since. I use a 3/16" 4TPI blade from Suffolk Machinery Corp. - Timber Wolf Band Saw Blades With my 9 inch saw I have no trouble cutting 3 inch thick basswood, and I have also cut 3.5 inch aged walnut with it.
                        I'll vote for the Timberwolf blades also. Big difference.
                          Yep. Timberwolf blades!
                          Arthur
                            Another vote for Timberwolf blades and I too like the 3/16th blade for detail cuts.
                            Randy
                              Rikon 10 inch bandsaw . Changed the way I work
