Paint pens
  • Paint pens
    Does anyone ever use acrylic paint pens when painting your carvings?
    I use Coloring Pencils with my Woodburning Pieces sometimes. Ifound that wipe on Poly isn't a good idea for sealing Pieces. It takes the color off . Must use Spray type Finish . Merle
      I've tried but the tips are never pointed enough to accomplish what I'm trying to achieve. Even the Fine Point Sharpie's don't work for me. If I do use a pen I use a sharpie with a very fine point.
        I've been using some "Duel point Brush Pens" that I got from Amazon, I've been trying them on my etch burning when I'm wanting to blend colors, but with the duel pint the work pretty good anywhere, they are a watercolor, check out if you're looking around
          I have used them for decorative accents on larger pieces that needed consistent colors, dots, or lines. The ones I used came form Hobby Lobby and you had to shake them really well before use.
            I've used the Very Fine Point Sharpies when I need a very fine line. Black, white, silver and Gold are the ones I've used. As an example, when I carve a crow or raven, then paint it black, the black pen is useless, is I use either the white or the silver to sign my name on the carving.
              I've been curious to try using technical pens with watered down acrylic paint. I am thinking a drop of paint to 8-10 drops of water might work. The solution would have to be the consistency of drawing ink.
              Bob L
                I have used paint pens for lettering.
                Dean
                  Used them and do not like them.....for one they dry up fast and cost too much. PaInt in a tube or bottle can last years.....you can do more with a liner brush. Fine lines are made with wax color pencils, pens and sharpies.....although have to find a finish that does not run.
                    All paints are color pigment mixed with a float media. The float can be water, acrylic base, or oil. If you are using colored pencils the base or float is clear wax for artist quality pencils or a white clay for student quality.
