Does anyone use the 3M flexible bristle discs in a Dremel to remove fuzzies?
Dealing with fuzzies
Yes. I mainly use the white ones. But not for every situation. A knife or a burner works better in certain areas. I use them kinda as an over all think, like brushing with a denture brush or tooth brush.'If it wasn't for caffeine, I wouldn't have any personality at all!"
Before the 3M Flexible Bristles came out I was using the gray scotch brite material the 3M sold on a mandrel. However, like any power sanding device you have to be careful that you don't remove wanted detail or add unwanted detail. Unless I come across a really bad piece of wood or leave an inordinate amount of fuzzies through my own incompetence, I currently use Doug Linker's method of aggressively brushing my carvings with a stiff bristled brush. I have a couple but when ever out with the wife looking at home goods I'm always on the lookout for an even stiffer one.
I like Eddy-Smiles,, have the 3 m things, But I found that they kind of lose the particle's and MUST wear safety glasses. I have a couple cheep wire brushes from Harbor Fright, and they seem to "de feather" the cuts. So you brought up a new on to me, I have I don't know how many of those Dremel parts,, still in the package?????????????
Cheers ChuckChuck
- Likes 1
Yes, I use the 3M Bristle disks.
Caught myself yesterday removing fuzzies as usual. What I use is a double-edged straight knife. The blades can be arrow-head shape or long and skinny. Two vertical stop cuts into the corner then slide the flat knife into the bottom.
Mine were made many years ago by a now deceased bladesmith. Look up Jamie Sharp and maybe even Herb Rice.Brian T
Originally posted by skip7083 View PostDoes anyone use the 3M flexible bristle discs in a Dremel to remove fuzzies?Last edited by DiLeon; 11-23-2022, 12:38 PM.. Explore! Dream! Discover!” aloha Di
- Likes 1
