Etching.
  • Etching.
    Well, Finally got the office/studio back in working order. My friend who helps me with the electrical stuff around here saw the knife I had mad for my grandson and asked if I would make him one. pretty much finished up with the knife still have to so the sheath. I thought I would try to etch the blade. Never done that, so I did a littler reading, The article I was reading was talking about using a battery charger. My battery charger is a bigger unit and I didn't feel like fiddling with it.
    I always save any AC adaptors off any expired whatever. I had one that converted to 18V/2.5A. didn;t know if it was powerful enough, guess what it was. hooked the positive to the knife and a Q-tip to the negative. Got some plain old vinegar add salt to it until with it wouldn't dissolve anymore Salt. Through the mixture in the micro wave for 1 min. Painted the area that I was wanting to etch with some of Pam's finger nail polish (don't tell her), let it dry scratch what I want to try and etch. turn the electricity on, dip the Q-tip into the solution started dabbing on the design.It didn't take long and you could see a reaction, like a dummy I lifted the Q-tip pf the design and things seem to stop Da.Haven't taken any pictures yet will wait until I all through.
    Just show you don't need a lot of equipment.
    Electroetching steel is a pretty cool process. Here's a pic of my shop built etcher that has DC etch and AC mark settings that I build on the cheap from plans that I found online. The DC setting removes the steel, and the AC lays down a dark oxide layer inside the etch to make things pop. I use a custom made stencil for my maker's mark, but nail polish works just fine when you aren't doing very many marks. It's a nice way to "sign" your work.
    Brandant Robinson
    Woodcarving Blog - www.theoldstump.blogspot.com
    Custom Folding Knives - https://www.therobinsonedge.com/
    Facebook - https://www.facebook.com/brandant.robinson.1
      Thanks for the reply Brandant, It is still experimental to me. Curious, what voltage do you use when using AC. Also, I doubt if I will get any but where did you get your stencils.
      Thanks
        If I remember right, it's 12V for both AC and DC. I get my stencils from here http://www.erniesknives.com. It's a little pricey if you're only doing a few marks, but you can't beat the resolution and crispness of the etch. Have fun, and let's see what you came up with.
        Brandant Robinson
          Thanks for the info
            How Interesting. I would enjoy picts if you make some, Joe.
              Copeau, check "Awhile back" post under this forum and you'll see a later post about this gizmo Thanks for asking
                thanks a lot !
