Files
  • Files
    I discovered today that a small triangular file works very well for me to get a straight line. Once that was in place it was easier for me to use the V or U tools and stay straight. It has some use for curves as well
    I use files, rasps and rifflers more than any carver I’ve met. A fact that has caused more than one old timer walk away shaking their head and mumbling. But a pencil and sharp tool should be adequate to carve a straight or curved line. Keep in mind you don’t need to take the full cut in your first pass. The tools must be sharp, not kind of sharp. Sharp enough to carve cross grain and leave a smooth surface.
      I use a file to clean up fuzzies
      Herb
        It is often helpful to make an incised line to guide further cuts, especially where you will have cross-grain curves.
          Jaeon: Any chance that you can cut to a straight pencil line on the wood?
          I found that a pull cut was a lot straighter than any push cut I could make.
          I'd do the first center line cut with something like a Moor large chip carving knife.
          Then come back to that on the two sides with a pair of skews, not a single V gouge.
            My filing makes fuzzies !:-)
              It's the pencil lines I am having a bugger getting straight. I will pull then. Have to look up what a skew is.
                I understand. Metal ruler and a pull cut with a chip knife.
                A "skew" looks like a chisel with an angled cutting edge.
                I hold them in my fist and drag them also to make Vee-cuts in form-line carvings.
                  Yep, that's what I do, too. I seldom use a vee tool; I prefer two cuts with a smaller chip carving knife. I find it more controlled.
                  Arthur
                    I also use files of all sizes and shapes both for shaping and detail cleanup. For doing lines I have a inexpensive set of gunstock checkering tools I use often. They give a clean crisp lines and are easy to control. I also like a chip carving knife and fined I can cut straighter with the draw cut.
                      Not a straight line tip, but for the smoothest curves with a v-tool - I always use a mallet. Light taps work very well.
                        This is a very informative topic. Thanks!
                          I can vouch for the gun stock checkering tools. I have a set for re- doing or creating new checkering. They are easy to use and incredibly sharp. If you get one keep it well oiled when not in use. Worth their weight in gold. I must confess I use files and rifler files as well for some fine stuff. I mean every sick puppy has to have all this stuff what can I say hehehehe. Happy carving
                            Glenn: you need kids who don't know what to get the old man for birthdays and Christmases. If in doubt, buy him a Lee Valley Gift Card. I own ALL THAT STUFF. Finally had to tell the kids to stop.
                            Mind you, they do get used, even just once a year, but the tools are at hand as needed.
                            I did leaf through a Brownell's Gunsmithing catalog once long ago. Got hung up in the stock finishing pages. Afraid to go back for a second look.
                              Hi Brian
                              Hehehehehe you sound like a kindred spirit. Dont have any kids . BUT had a load of airpoints to get rid of before the expiry date so converted them to vouchers for a harware store and got everything I could think of that I might need for working wood before I retired. What can I say I just love retail therapy!!!!!! Like throwing a kid in a candy store. hehehe.
