Someone asked about how to carve noses ...
Now it's a little hard to do just a nose ...
so I think I will do the whole face. I decided on a pattern from the Woodspirits and Greenman book that Chris, Shawn and I worked on.
This pattern has been elongated to fit a 8" wide by 14" long by 1" thick basswood board. I am going to try to include ALL the steps ... if I miss something I am sure that someone will be kind enough to let me know.
This is what I would consider a beginner's level project ... if I get too simplistic, sorry!
Step 1: I'm using an 8" x 14" x 1" rough cut board of basswood. I always start by giving the wood on all four sides a good sanding.
Step 2: I've sized the pattern to fit my board and used rubber bands to hold it into place. There are two sheets of carbon paper underneath. One sheet was not quite large enough to cover the entire board. Trace using an ink pen.
Step 3: Check a corner of the tracing before you remove all the rubber bands. I have only traced the main outlines of each area. Since much of the wood will be rough out cut there is no point in tracing all the details at this point.
This free online tutorial is brought to you by ArtDesignsStudio.com
Susan
Susan
