Drying varnish
  • Drying varnish
    Used oil based spar varnish on some ornaments and it won't dry. Been over 48 hours, and they are still somewhat tacky. Any fix?
    Tom H
    http://beginnerscarvingcorner.blogspot.com/
    Tom, reading this article http://www.thewoodworkingcatalog.com.../sep96/finish/ sounds like it just may need more time. Sorry.
      Thanks Sappy! Articles make perect sense. The varnish was a bit thick after stiring , and I dipped the pieces. Don't be sorry, it's the easiest fix here is.
        I've had a couple of projects that I've done in the past year that have taken a while to set up after using the spar varnish. It seems to create more problems than regular poly varnish, might have something to do with the formulation. As a matter of fact one piece I did took almost five days to finally get to the point where it wasn't tacky. They all eventually dried fine but in the case of the last one mentioned, I think the humidity that week had a lot to do with it. Go find something smooth to sip on while you wait Tom. Thanks for posting that link Sappy, great information for us less informed.
        Tinwood
          Thanks guys! I feel kind of foolish. What you've pointed out I should have known. However, there is an up side. My wife said that with this post I have confirmed my masculinity: no common sense used, and did not read nor follow the directions.
            LOL! Sounds familiar.
            Arthur
              Ok, silly question...why are you using spar varnish instead of regular poly or even a spray lacquer to finish ornaments? Are they going to be outside? Just asking....
              Donna_T
              From Missouri
                Not a silly question! Just a silly person applying the finish. The other stuff was out of reach. You probably think I'm kidding. I am not! Just too lazy to get out of chair, walk across shop to the finishing cabinet and get what I know I should be using.....Had been using spar on a sign.
                  We fellows salute your masculinity with our best Tim The Tool Man man grunt!
                  Tinwood
                    I recently had the doors of my house, that lead outside, replaced. The installer advised that my installation warranty required that the unfinished wood be painted. I told him I wanted to retain the natural look. He recommended varnish, so the look on my face, and continued. I recommend Minwax Polyacrylic Finish. It is water based and has no smell.
                    I used it, loved it, and started using it on some of my carvings. It is on the front of the owl I am carving. The close up photo is a little blurry but that is the best my cameral can do. There are 4 coats on the "ice" in front of the owl and I anticipate 4 more to get the very shiny effect I am seeking.
