olive oil for finishing
  • olive oil for finishing
    ok i ran out of mineral oil and usually i use mineral oil and wax for a final finish can i use like olive oil or vegtable oil?? is a oil an oil ? this is merely decrotive not to be used for food etc just want it to shine some
    You can use olive oil, but it might go rancid.
      try a couple coats of tung oil. dries completely unlike others (linseed) and second coat will build a bit of a shiny film
      Buffalo Bif
      bflobif.com
        Like Steev says, olive oil or vegetable oil will go rancid. Use an oil specially formulated to use on wood as a finish.
        Tinwood
          I think "Boiled Linseed Oil" will dry, Buffalo, but not the raw?
            I have heard of boiled linseed seeping out of wood pores months after application. Doesn't seem worth taking a chance on.
            I think linseed is fine for an outdoor ornament- excellent protection, easy to re-apply every year.
            Buffalo Bif
            bflobif.com
              Thanks Buffalo and was curious since boiled linseed oil is used in old oil paints, in artist oil paintings, on gun stocks, and for antiquing wood carving pieces. Currently, I use it for antiquing the wood carvings I do, even those for inside.
              I do agree not taking chances for any "unknowns," hence the question.
              Thanks again...
                Your experience trumps mine, WB. I have stayed away from linseed based on stories and advice of others, I have no experience of my own.
                Buffalo Bif
                bflobif.com
                  Properly heat-baked into the wood, olive oil can't go rancid.
                  I carved 70 spoons and 30 forks and what stock I have left still smells sweet and fresh, even with no use at all.
                  The oils will sweat out of the wood, even years later (not rancid) when the wood gets warmed up.
                  Backward application of Charles' Law of gas physics.
                  Done right, it should be a coating which cannot be washed off for decades.
                    Hey Guys , I use Boiled Linseed Oil on all my Carvings and have had no Problems at all . That is the first thing I put on my Carvings before Painting . I use it as a Sealer and like the Color that it gives the Wood , in fact that is the Skin Color of my Wood Spirits and Santa Clauses . I leave it dry over night before Painting . I know a lot of Carvers don't use it and that's their choice , but I have used it with success. Just saying. Merle
                      Is there a shelf life to BLO? I have inherited a very old can and was wondering if it is still good? How would I tell?
                        I really don't know , maybe the Smell or how thick it is or Lumpy . Try it on a Piece of Scrap Wood and see how it does . It's not that expensive maybe a new can would be better on a Good Piece . Merle
                          Well, a google search leads me to believe there is no shelf life except for drying up. I’ll take a look at it and try it on something to see what the results are.
