Can beeswax finishing wax be applied to painted carvings? And if so, would the painted carving need to have some sort of sealant on it first?
Beeswax Finish
I have used beeswax as a waterproof finish on birch carvings (dishes) at my kitchen sink.
It picks up dust and you can't wipe it off. For appearance, it isn't matte, satin or gloss unless you power-buff it.
I applied it melted (ultra messy) and did my usual oven-baking process to set the wax into the raw wood.
As waterproofing, it is exactly what I wanted but I'll never bother with buffing up any kind of a shine.
I can buy acrylic finish (matte, satin and gloss) in a bottle to mix with paints or apply alone.Brian T
- 1 like
I use Howard Feed N' Wax after I have dipped my carvings in BLO. I paint with thinned acrylics. All the BLO and Howard's finish does is soften and deepen the colors. I have never had an issue with the Howard product.
I let the Howard product sit on the carving about 20 minutes before I wipe off with a soft cotton cloth. In my opinion, it really finishes off the carving.
I have never sealed a carving either before or after painting, unless you count the BLO and Howard product.
- 1 like
I seal my carvings with satin Deft lacquer first then add a coat of Howard Feed N Wax. I let the Feed N Wax sit for 20 minutes then rub it down with a cloth and buff it good with a horsehair shoe brush.Keep On Carvin'
Bob K.
- 1 like
I don't understand the reasoning behind using wax over a protective clear finish coat. Another thing I don't understand is the use of Feed N Wax...you can't "feed" dead wood, and it doesn't penetrate a clear coat anyway. Of course, those are just a couple of the very many things I don't understand. Not trying to step on anyone's toes here!Arthur
- 2 likes
Bees wax is a soft wax, Johnsons floor wax is a harder wax, both will attract dirt like Brian said.
Both will cover the paint without sealing it, however if you ever wanted to remove the wax sealing first would be a good idea. As for adding wax, has anyone tried a product like wood floor wax and shine? It dries hard and is removeable with a warm water and a rag. Unlike poly, which would require sanding to remove. Just wondering out loud here, thoughts?
- 1 like
Thanks. I originally got interested in the "wax" finishing question because I have seen a foreign carver's work and that is what he uses. The finish on his carvings and what it does to the colors is stunning. It creates a very muted and elegant appearance in his work. (Plus he must spend hours sanding his work.)
- 1 like
You can also use Watco Wax. Brush on, let sit for a day, then buff. I use a 50/50 mix of dark and natural.
SteveSteve Reed - Carvin' in the flatlands!
My FB page:https://www.facebook.com/stephen.ree...7196480&type=3
In wood turning they use turtle wax - dries hard and with a shine... They also use turtle wax polishing paste - very fine grit to clean up the wood (some use 6000 grit for that). Wax tends to pick up but there are hard waxes and Bee is a soft wax. Try out and test.
My great Uncle's carving had wonderful stain paint without protected cover. So far so good. These have been done for almost a 100 years. And while "Ma's apron (Mountain men and Ma) is a bit dirty - most white things that old are. Looks like it must have been thinned oil paints. He carved while waiting for work. He was a medical doctor in Indianapolis.
- 1 like
You can put wax over any type of finish, but you can’t put any more finish over the wax. I use beeswax on occasion, as I have a huge chunk of it. But it smudges more than other waxes - it almost seems to remain slightly tacky - and doesn’t produce the same degree of luster as some others. My preference is carnuba wax. I’ll melt it down and mix it with mineral spirits until it’s a paste wax consistency. A food wax topcoat is wonderful. A good wax topcoat can be really beautiful
- 2 likes
