I read that low temps are not good for curing stains finishes and I'm a bit worried.
I have a small, unheated but closed balcony, about 4' x 7' that I use as a workshop (apartment living means space is scarce). Being unheated means that it generally gets pretty cold in there so I do my work with a jacket etc. The conditions I guess are sliiiightly better than a small shed.
I generally carve small stuff, less than 4" across in any direction and I was wondering how I should approach staining with a cold workshop.
1. How much do low temps matter when staining (using minwax stain and polycrylic)?
2. If its bad to cure at low temps, should I keep the carvings inside while curing? Or will the fumes be too bad for me and my girlfriend to be in the same room as the carvings?
3. Can I put the carvings in a plastic storage box to keep the fumes in while it cures (and the open up the box after a few days when its supposed to be cured)? Or will the finish pull a trick from the linseed oil playbook and catch fire or something?
4. Should I keep the cans with the stains/finishes etc. inside? Or are they ok in low temps?
