Clarification
  • Clarification
    I've been carving for a while now and am starting to slowly accumulate some good knives and gouges. Now, curiosity has driven me to learn about new tool that I may have to add to the collection. Most tools wins right? Anyway, I've just learned of a gouge type that I've never heard of before and maybe someone can enlighten me as to just what it is. The gouge is called a "soft vee". What the heck is this? (A picture would be nice too.)
    Tinwood
    Hi Tinwood
    I took this explanation from the treeline website.
    Flexcut's Soft V-Tool is similar to a standard V-Tool, but the point of the V is slightly rounded, allowing it to double as a small gouge. It can also be used as a parting tool for creating lines and textures, and it can be rolled onto its side and used as a straight chisel for flattening.
    Hope this helps
    Larry
      Among Pfeil (Swiss Made) carving tools these are called Staehli gouges. They come in three widths: 3mm, 6mm, and 20mm.
        Hi Tinwood, I think you just learned all you need to know about that Tool so go ahead and get it . you know you need it . Ha,Ha. Merle
          You probably ought to get the complete set from Pfeil. Sure as shootin', as soon as you start using a soft vee, you'll run into a situation where you need a softer one.
            I thought all V-tools were like that right at the tip.
              The "softer" one would likely be a #11 - a U-gouge - a little tighter curve at the apex with curved sides, but not a segment of a circle like all the #2 thru #9 gouges.
                Tinwood
                here's a picture: http://stadtlandercarvings.com/V-Too...le_p_8166.html
                http://www.tristatecarvers.com
                  Here is one by Drake. It is a little over 1/2' wide at the top of the wings and the wings are approximately 90 degrees. I use it a lot!
                    Dang you Tinwood
                      The V-gouge with the curved apex and straight sides is a #14 in the Pfeil lineup, but the angle is 55 degrees. It comes in six sizes.
                        Here are three soft v tools. The OCCT "Ortel", OCCT "Stetson", and the Flexcut 1/2".
                        Hope that helps!
                        Bob L
                          Who is OCCT? The London Pattern Book and the Pfeil version of that, I can read.
                            I believe OCCT (Ozark County Carving Tools) is formerly Mike Shipley knives
                              I have found a this tool very usful. working around faces and areas where I want a Vtool but want to avoid the sharp line at the bottom of the cut,
                              Randy
