I've been having a problem for years where I hone my chip carving knife it eventually ends up with a concave edge. Very frustrating because the chips get stuck more often than not. What causes this concave edge and how can I avoid it?
How to prevent concave edge on chip carving knife?
Brad are you saying one side of the edge seems to be roled over or both edges sides are hollowed in? Do you use a flat stone or power sharpen?
If there is some flex to the blade and you use too much pressure on the stones, it would be possible to take enough metal off the middle of the blade to cause a concave edge, but since you rarely use more than the tip for chip carving it may not matter.
Please describe what you mean by "chips get stuck."Last edited by pallin; 04-13-2020, 01:44 PM.
Originally posted by pallin View PostIPlease describe what you mean by "chips get stuck."
As Pallin suggested check how much pressure you a using on the stone as well as the strop. Pushing down to hard on a leather strop can cause a subtle curve in the cutting edge. The leather compresses and as the blade move down the strop and the strop decompress it can push up on the edge. Almost the same effect as rolling the edge if you turn your wrist at the end of the strop. This was a issue for me until another carver showed me what I was doing. From your above description could there be a issue with your angle or depth of cut on the last cut on the triangle?Last edited by Randy; 04-13-2020, 04:42 PM.
When I do European style chip carving I make two pressing cuts to define the sides of the triangle. These are followed by a slicing cut to release the chip. I have even done the slicing cuts with a fishtail gouge.
https://forum.woodcarvingillustrated...-sister-repost
Originally posted by Brad I View Post... if you put the sharp edge down on a straight edge it has a bit of a concave instead of flat edge. .....and I'm using flat ceramic stones and leather strop
Since I cannot see what you are doing, I can only take a guess... I'm assuming you're letting the edge closest to the handle come off the stone (a common issue if using a circle or figure 8 motion). If this is true, and you're applying a bit more pressure on the handle side, the edge of the stone will remove more material between the handle and the tip, causing the shape you're describing.
My suggestion is to pull the knife along the stone (avoiding circular motions) and ensure the entire edge stays in contact with the stone/strop. Applying pressure with an index finger at the center of the blade will help maintain even pressure along the entire edge.
Originally posted by Randy View PostAs Pallin suggested check how much pressure you a using on the stone as well as the strop. Pushing down to hard on a leather strop can cause a subtle curve in the cutting edge. The leather compresses and as the blade move down the strop and the strop decompress it can push up on the edge. Almost the same effect as rolling the edge if you turn your wrist at the end of the strop. This was a issue for me until another carver showed me what I was doing. From your above description could there be a issue with your angle or depth of cut on the last cut on the triangle?
Originally posted by pallin View PostWhen I do European style chip carving I make two pressing cuts to define the sides of the triangle. These are followed by a slicing cut to release the chip. I have even done the slicing cuts with a fishtail gouge.
My concave blade wasn't so much of a problem until I started doing this type of carving. If you zoom in, you can see around the edges evidence of unnecessary second and 3rd cuts. Virtually all of the internal triangles appear sloppy because it's impossible to get a clean cut without multiple passes. A slicing cut can be deadly to the carving as well because everything is so fragile and the angles are so weird.
Yes, circular patterns are a special problem because the angles relative to grain direction are constantly changing. You have to think about where the cutting pressures will go.
In answer to your question about switching from knife to fishtail gouge - I often do the plunge cuts for multiple triangles before starting the slicing cuts with the gouge. It would seem that using a #3 gouge for flat, slicing cuts would increase the chances for misalignment of the final cut, but that's not the case.
Plate 021.jpgLast edited by pallin; 04-15-2020, 12:12 PM.
