Installing a palm type handle?
I have cut the shaft off of a pfeil fishtail gouge and would like to install it into a new pfeil palm handle. I have rounded and tapered the lower ½ of the shaft. I’m not sure of the best installation method and have several questions.
a. Should the hole size be just slightly bigger than the tip of the shaft?
b. Should I heat the shaft red hot then insert it into the handle? or
c. Should the handle be hit with a hammer driving the gouge into the handle using inertia?
d. Should the handle be soaked in water to soften the fibers before installation?
e. Should wood glue or epoxy be used?
f. How is the ferrell mounted?
I realize that I am over-thinking the installation but I would like to know the best method as I would like to make a set of palm fishtails for daily use.
Any help/guidance is much appreciated.
