I am attaching a handle to a knife blade What is the best glue to use is gorilla glue good enough?
glue on knife handle
I am not sure about Gorilla Glue for knife handles. It works well on wood and textured surfaces. I have never used their epoxy. I have made a few knife handles and used "BladeBond Ultra" recomended to me by a friend who is blacksmith and blade maker.We live in the land of the free because of the brave! Semper Fi
Are you going to put pins in the handle, if not, notch the sides of the tane for an area for the glue to harden in. I always felt that this gave a little more control to keep the blade coming out of the hand To answer your question, regarding the knives I make I always use two-part 5min epoxy.. . .JoeB
I use Bob Smith 30 min but just because that is what I keep around. I have also used whatever 5 min epoxy I had and have never had a blade get loose. I agree with Joe and always carve a tight recess for the tang to nest in. I like gorilla glue in certain applications but don’t think a polystyrene adhesive would be the way to go on a knife handle.Last edited by Nebraska; 05-11-2022, 07:25 PM.
I have surface-hafted a dozen or more blades (Pacific Northwest Coast First Nations style) into hardwood handles. I have always used JB WELD epoxy. This is the usual A+B mix, it even has crushed limestone in it.
Then I cover my messy work with a FAQ cord whipping.
I have never had a blade come loose.Brian T
Originally posted by pallin View PostWe're assuming that the handle is wood, but you didn't say. The most secure attachment would be rivets through a full-length blade tang.Chuck
- Likes 1
