Hi everyone. I made this v-tool and skew from 5/32 music wire. The handles are fir hand planed into a tapered octagon. The v-tool still needs a tuning up, but is already cutting better than I thought it would. I made it by putting a long angle at the end of the rod, filed it with a triangle file to make the wings, then sharpened the outside. I'm going to try a gouge next using the same method.
Diy v-tool & skew
Tags: None
👍 2
Wow Anders that really looks great.Mark N. Akers
👍 1
Nicely Done. Being able to make you own tools is a great plus.We live in the land of the free because of the brave! Semper Fi
👍 1
I actually bought some 5/32" music wire to replace some broken springs in the seat of my ancient (1970) Chevy truck. I laugh when I say ancient- that truck was built during my last year of high school!If I do use the O1 tool steel I bought, it'll be for bigger tools. I (fortunately) already bought the full set of Dockyards.
Originally posted by joepaulbutler View PostMakin g my juices start to perk"from 5/32 music wire. " can you expand on this a bit more
It was originally used in pianos and that is how it got its name. It's tempered high carbon spring steel. Good stuff.
👍 2
I went to a shop that caters to hobby builders, like radio control airplanes, to get mine. Even the big box hardware stores don't carry that, as mentioned. My youngest brother made a fixture and bent that wire into shape for the truck's seat springs. I've had carpal tunnel release surgery on both hands, and they're mostly better, but he cranked out that wire bending like a machine. #Bender
👍 1
104 Pcs 40 cm Straight Stainless Steel Spring Wire Spring Assortment, 12 Different Full Hard Spring Steel Wire, 0.3 mm, 0.4 mm, 0.5 mm, 0.6 mm, 0.8 mm, 1 mm, 1.2 mm, 1.4 mm, 1.6 mm, 1.8 mm, 2 mm, 3 mm
$16.99$16.99
FREE Delivery Fri, Sep 2
Only 6 left in stock - order soon.
Found this on Amazon's website FYI
Joe- K&S Precision Metals. It's tempered high carbon spring steel. You can find it in real hardware stores....not lowes or home depot. Hope this helps. I wouldn't mess with stainless......too hard to work with.
👍 1
