Adjusting this Saw
  • Adjusting this Saw
    Lately I have had problems adjusting the band saw. most times it 's not bad but this last month after changing blades
    Have a slice.. 1/32 nd - or 0.079375 cm 2023 Wood cut.jpg
    A slice of wood
    Chuck
    Chuck,
    I can’t tell what the photo is showing.
      Is that oak, Chuck?
        Adjusting the bandsaw is major hate of mine...smile takes me forever to get it adjusted just right.
          I am with you , Di! I get the shakes just thinking about it! Although, since I got rid of the 3/16" blade and when back to a 3/8" blade, it is easier to adjust!
            Hey Bill it is Russian Olive, and ED the piece is very thin.
            And DI and Tbox, pay my way and I'll come adjust yours
            Chuck
              Hi you two and anyone that's watching. I called my manufacturer and a conversation w him was a profitable thing. He also sent me instructions that did not match the ones in the book that came with it. SO that's that. If anyone wants a copy I'll post it some where.
              Chuck
              Chuck
                Every bandsaw blade needs to be adjusted for drift. Set up your fence square to blade,make a cut 8-10" long you'll notice the cut drifts one way or another. Loosen fence and move the fence until the cut is square. Most bandsaw are a poor design. Some cabinet shops use a point fence- a dowel. I had a Grizzly bandsaw with lennox skip tooth blade, probably 1/2" x 3 tooth. Go here for info https://www.highlandwoodworking.com/...aw-blades.aspx Mark Duginski is the BS guru he might have a better explanation. I could resaw to 1/8 easily-never needed to make thinner veneer,but it is doable.
