I posted two more photos in the knife making series, only one photo left, the finished knife.
Knife Making
Re: Knife Making
Thanks Butch,
I posted the finished pictures of the knife today.
www.picturetrail.com
Type CARVERS-R-US in the box
Re: Knife Making
I do most of my shaping, grinding, and sharpening on my 'Burke Sharpening System'. I also have an old grinder that I use a little. To get the curve where the blade meets the handle, I use a dremel with a 1/4' sanding drum.
I determine the correct temperature for heat-treating with a 'cow magnet' NO! it doesn't attract cows! It's about a three inch long magnet shaped like a small hot dog. It is fed to cows to collect wire etc. The hard part is getting them out of the cows. When the metal is heated enough that the magnet will not attract it, then I have the correct temperature.
I usually put a good finish on the blade before tempering it with the torch, I temper shortly after heat-treating the blade.
The final sharpening and polishing is done after tempering.
Re: Knife Making
Usually, I temper by color, but when I am tempering several blades, I do use a Toaster oven with a good thermometer
Held at these temperatures for about 45 - 60 minutes (for most small tools).  I try to stay between 400-425 degrees
approx. Rockwell C results.
350 Â deg. F Â 62/64
400 Â deg. F Â 61/63
450 Â deg. F Â 60/62
500 Â deg. F Â 58/60
Re: Knife Making
For anyone looking for knife handle wood, Ebay has a good selection. I just bought (36) 1' x 1' x 4' pieces of African Blackwood for $21.00 + $10.00 shipping. That's about the cost of one good knife. I have already made one handle from it, and it turned out very nice.
Blackwood is a very dense black wood with gold/brown streaks running through it. If linseed oil is applied to it, it will turn pure black. It finishes as smooth as a piano key and appears to have visible depth to the wood.
It could present a problem with being too smooth for a good grip. I have considered turning a set of carving tool handles ftom blackwood. That will give me an excuse to buy more wood!
