The larger ones particularly allow the quick removal of lots of wood for roughing or relieving backgrounds in relief work. Flatter gouges can then be used to finish up.
Since they are deeper than they are wide, there is less of a tendency to bury the corners in the wood - which produces splitting
Thanks Rick W! :-)
What size you recommend for a beginner that doesn't carve really large pieces yet?
My 9/15 would be about as shallow as it gets in this class of gouges.
I'll suggest two: 11/8 and 11/15, little and big. Start with the 11/8. When you find that it's taking forever to remove waste wood with any speed, that's the time to consider something wider/bigger. You will understand when that happens.
I find them most useful. By the time I i get through with a carving I've most of the different sweeps out, different size, I just carve to be comfortable, over a period of time I've collected a nice verity of carving tools and I don't want to show preference . . . .JoeB
As others have said, yes they are very handy for wood removal. U gouges can be like sculpting with wood. Though as all gouges, they are only effective if kept sharp. And though they are deep, I like to avoid using the full depth and only use about half, about where the sides become straight. Flip them upside down and they can be used to create vine like structures.
The larger #11 gouges (Veiners - and Veiners are NOT V tools), say 11/15, 11/18 etc, also are bery useful not only for hogging off a lot of wood quickly, but by laying them on their side, they can be used like a flatter gouge - say a #3, for smoothing things up
